Hello folks, wanted to share some amusing structural issues I found this week and get some feedback.
We tore out our old ceiling and exposed a double 2x10 beam beneath what was previously a wall "holding up" my rough cut 2x8 joists below the master bedroom and the studs between the two bedrooms.
However, I'm not sure they're carrying much of the load with gaps between wood all over the place. Needless to say, the 2nd floor vibrates when anyone over 150lbs takes a step.
(Refer to pics attached.)
The problems are:
1. The double beam is not install correctly (imo), it's below an apparent 1x6 plank and behind the 1x6 are little 2x4 pieces that are supposed to be holding the joists. Some of the 2x4's are missing.
2. Beyond that, the beam is not flush with the plank.
3. Further more, the studs that apparently were there previously were crudely hacked off and are now FLOATING.
So, to the plan, we pull out the 1x6 that is useless, move up the beam and use proper joist hangers with it, but the questions are:
Question 1:
How do we 'un-float' these studs? I imagine if we simply cut them 'flush' and jacked up the beam we risk popping the drywall upstairs.
Question 2:
The 2x10 will still hang lower than the rough cut 2x8's, do we NEED a lam beam, or could we do doubled or tripled 2x8's? I have a highly recommended/rated licensed contractor doing the work, but we're not engineers and can't afford an engineer. The span is 12 feet and we'd of course be installing at least a 4x4 below each end in the basement. (The nearby structural engineers won't step in the door for under $400.)
-jason
The problems are:
Question 1:
Question 2:
-jason
