1 - 9 of 9 Posts
I have to remove the glass in the door of my woodstove. There are plates with screws in them that hold the glass. I have been spraying the screws with WD 40 so tonight I tried to remove them, I got all but 2 out . The 2 that are still in are almost stripped. I am afraid I am about to really strip them out. Any tricks to get these out?
Are you worried about stripping the threads or the screw-driver slot. (assuming a slotted screw)
If the screw-head is damaged, one method is to drill a hole into the center of the screw-head. A drill that is equal to the screw thread minor diameter is used.
With this method, the head pops off, allowing the plates to be removed. Then, hopefully, enough of the screw will be left, to snap Visegrips and twist the screw out.
If there isn't enough of the screw left to grasp continue drilling down through the screw, then 'tap' new threads using a tap of the correct size.
screwed
well, the head broke off of one screw, the othere will brake too I am sure and the threads are stuck, I guess I have to drill out the rest of the screw and re-tap it. Do you think these are stainless steel screws because they are exposed to high temps inside the woodstove? Man this stinks.
Hey! Thats why we do it ourselves because we love the challenge! :laughing:
It possible, although stainless would be less likely to 'freeze' in the holes. :censored:
No, we do it to save money. Sometimes I wonder if the aggrevation is worth the money. Thank you for you help and input on this matter though. This is a great website to gather advice and info.
1 - 9 of 9 Posts
