I was wondering which Peel Away product to use to strip the (almost certainly lead-based) paint off of a plaster wall (approx. 80 sq ft total) after removing wainscotting. The first picture shows the wall, I was thinking to scrape whatever I can scrape off (wainscotting adhesive and detached paint) and then apply Peel Away.
A few years ago, I used Peel Away 1 to remove some stubborn old paint off of a brick wall in my basement because I wanted to have an exposed brick wall. The second picture attached is showing a circle with Peel Away 1 applied as a test before I proceeded with the rest and the old paint around (so the circle was just like the rest before I applied Peel Away 1 to it).
Peel Away 1 did an EXCELLENT job on brick, however, I am wondering if it may weaken plaster, i.e. if it is applicable here or if I should use another Peel Away product.
Thanks
Thanks
