1 - 7 of 7 Posts
Hi,
Im strapping out the cathrrdral ceiling with 1x3 under scissor trusses. Should i start at peak or sides to measure for 16" centers?
Thanks
Sent from my SGH-I337M using Tapatalk
Property Mgt/Maint
If this is strapping for drywall, usually its installed from top edge working down.
So start at the peak is what I would do
Just curious about why you would strap out the ceiling for sheet goods?
Discussion Starter #5
Not sheeting right away. Space for wires, Trusses arent spaced exactly....
Registered User
I usually check overall length for division of 4', OSB at 3" wide rip doesn't sit still for long if a vehicle parks there (humidity).... install waxed side toward you.
Gary
1 - 7 of 7 Posts
