Am strapping vertical runs about every 18 inches. I am wondering about horizontal, doesn't there have to be some freedom on the horizontal runs?
Thanks
Thanks
Use plastic anchors at max spacing of 6ft for 1/2" and 3/4" pipe. I usually go 4ft. Plastic anchors will allow some movementAm strapping vertical runs about every 18 inches. I am wondering about horizontal, doesn't there have to be some freedom on the horizontal runs?
Thanks
Ok so should these be loose or snug? Also I already bought copper and was using a thin rubber seal if you will between the clamp an pipe, on the verticals.TheEplumber said:Use plastic anchors at max spacing of 6ft for 1/2" and 3/4" pipe. I usually go 4ft. Plastic anchors will allow some movement
The talons(first image) shown in this link work very well on pex or copper. They shield the pipe from direct contact with wood- no need for cushion stripsOk so should these be loose or snug? Also I already bought copper and was using a thin rubber seal if you will between the clamp an pipe, on the verticals.
Aren't you replumbing a whole house?Am strapping vertical runs about every 18 inches. I am wondering about horizontal, doesn't there have to be some freedom on the horizontal runs?
Thanks
Ive used copper straps on copper pipe with copper nails for 45 years and never had a problem, so what are you all talking about ?????
Get some pictures up sometime so we can pick you apart :jester::thumbup:
Good luck with the fire up---
If you have some one else turn on the water--listen for air hissing---try to stop the water before the air leaker becomes a wet joint---less time wasted waiting for the water to drain out for the fix----
