Heres the situation. I have a Liftmaster 1280lm belt drive opener.
It will start to close and then return. I've had a garage door guy out way too many times to count. The sensor eyes are bypassed, so I know thats not the problem.
If you put a ground wire bypass adapter on the power cord it works fine???
The garage door guy is telling me theres not enough power coming into the outlet??? I've tested the outlet and theres 119v_120v
Could this be the case? If so.. what would not grounding the unit effect?
I'm not going to have him come out again until I do a little research.
Any help is greatly appreciated.
Thanks for letting me ramble on.
Mike
Mike
