I have 10 lay-in four tube fluorescent fixtures in my shop, with a total of 20 two bulb ballasts. Three of the bulb pairs were flickering, so did the standard resistance test:
Neutral white wire to each hot out, red, blue and yellow. All three were showing around 10 ohms on the blue wires, red and yellow were fine. Not liking coincidence, I checked all 20 fixtures, and all are showing 10 to 12 ohms on the blue wires even though all of the other fixturs are working just fine. What am I missing? Thanks in advance for any thoughts.
That test doesn’t mean a lot on ballasts. The diagnosis is super simple: swap in a known-good pair of bulbs; if still flickering, the ballast is defective, and swap the ballast.
I tried putting new bulbs in and they work for a few days, then the ends get black and they start flickering. Maybe the high start voltage is leaking after startup?
Destroying tubes is a classic failure symptom of an obsolete magnetic ballast. (The ones that buzz, and are quite bulky, and start hard in the cold, and cause 60Hz flicker, even on a good day).
Do not hesitate to swap them out for electronic ballasts. You want the
rapid-start or
programmed-start variety, since those are directly compatible with your 2-yellow 2-blue 2-red wiring. Avoid “instant-start” as they are confusing to wire.
Combine that with modern 90 CRI tubes (best light on the market) and you won’t even believe they are fluorescent lol. They will serve you well for decades.
This is the time for a technology shift. Your upgrade path is 1 of 3 ways:
T-12 tubes, electronic ballast: All the benefits of modern fluorescent and you keep your old tube type, so your old stock of tubes will keep working. However the newer tubes are really nice, so research the “CRI” on your existing stock of tubes. If it’s less than 90, maybe it’s time to get 90 CRI.
T-8 tubes, electronic ballast: These are more efficient than T12 tubes, so you’ll save energy for the same light. They snap right into the same sockets. But they are not electrically compatible; T8 tubes on T12 ballast (or vice versa) is no-go. This is what I am doing at our facility, which has about 150 ballasts.
It’s six of one, half-dozen of the other to go T8 vs T12, but supposedly T8 tubes will continue to be available and T12s will be deprecated. I don’t see that happening for a long time.
LED Conversion, plug-n-play: They now make LED lights in the shape of a T-8 tube, which will snap right into your fixture. The plug-n-play variety require you to maintain a working ballast (T8 or T12 they don’t care). This also means you can rollback to real fluorescent once you find out how hokey these things are. Or
LED conversion, direct-wire In this case, you remove/bypass the ballast, and shoot 120V straight into the fluorescent socket. So you’re all-in on LED at that point.
I personally find that both kinds of LED have serious quality problems, largely because the business is such a “gold rush” and you have lots of cheap bottom-feeder overseas builders dumping sheer volumes of junk onto the market. It’s not price competitive; real modern fluorescent ballast+tube upgrades are same or cheaper. And you’re getting GE/Philips ballasts and Sylvania/Philips tubes, which will probably outlive you in a home shop setting lol.
By the way, you can get 4-lamp ballasts now... though most are “instant-start” with a bit different wiring. 4-lamp rapid-start ballasts can be found. The advantage to rapid-start is it’s much easier on the tubes, so longer tube life.
Electronic Ballasts have a figure called “Ballast Factor”. 1.00 is normal brightness. One guy on eBay has programmed-start (excellent) ballasts for $5, but those are 0.71 ballast factor, so pretty dim. If it wasn’t for that, I’d have bought 50 of em for my own conversions!
