Hi,
I have a home (circa 1940) that has some kludgy wiring. The basement stairs has a 3-way switch; 1 switch at bottom of stairs, 1 switch at top of stairs and two lights in between. I know that the wiring must not be up to current code, because whenever I operate the lights, a big magnetic field is created, which shouldn't happen if wired to any of the currently approved configurations. Anyway, both switches have 3 wires going to them. In testing the light sockets, I found that one light has hot in the center and neutral on the shell. However, the other light is hot on the shell and neutral in the center, and this is true for all on/off switch combinations. This socket is housed in a box that has two wires running to it. I turned off the power and i could clearly see the black wire tied to the neutral screw of the socket, and the white on the hot screw. So, it seemed logical enough for me to reverse the wires, which I did. However, when I turned the power back on and flipped the switch, sparks were flying :huh:, so i immediately turned the switch off. I then reversed the wires back to how they were and the light is working again. I can't understand how flipping 2 wires going to an A/C bulb would cause this to happen and am hoping someone can shed some light on this for me.
