1 - 8 of 8 Posts
I have been painting rooms for a few years now. Mostly in my own home. I have gotten really good at cutting straight lines. But there is still one thing with my brushes that messes me up. Sometimes a few bristles will strick out at the very bottom edge and create little streaks. I am using Woodster nylon brushes with water based paint. Sometimes it happens, sometimes it does not, and all with the same brush. I cant seem to figure out exactly what is causing it. Too much paint, not enough, bad angle? The brushes seem in good condition after I clean them.
Any ideas on how to fix this, is it normal?
Usually Confused
Same response as the pro. Often I lose or wreck the thing it came in (shuck !?!) and just wrap the brush in paper towel and an elastic.
Premium Member
Really just the nature of the Beast. Nylon brushes and the tiny filaments can do that sometimes. I usually cut any “strays” off with a razor blade and they are good to go once again.
I think that's one of the differences between an amateur and a pro. A pro instinctively knows how to keep the bristles working together. If a bristle gets weird, he instantly knows something is not right and resets it. Or he cuts the thing off.
It helps if the brush is a little damp with water before you put it in the paint. Never use a dry brush or roller.
I have never prewet a brush or roller, nor have I worked with anyone who did. Not saying its not a good thing to do, just saying its not a must.. But yes, cut it off.
1 - 8 of 8 Posts
