I'm going to put a stone veneer on my interior gas fireplace. The walls are already a painted drywall. What is the best product to use for adhesion to the drywall?
You cannot adhere an adhered veneer to drywall, painted or not. You have 3 choices:
Screw 1/4" hardie backer to the drywall, hitting the studs.
Remove the drywall and screw 1/2" hardi backer to the studs.
Lath over the drywall (or bare studs) and lay down a scratch coat of stucco.
No matter which one you choose, use a polymer modified thinset to attach the veneer.
In some cases, you can adhere thin brick to drywall, but never over painted sheetrock. For thin brick on drywall, a specialized base-coat material is applied and then the brick faces are thinset to it. Suitable for small areas like backsplashes, but not for a fireplace or wall.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
DIY Home Improvement Forum
