I work at a medical facility and we had a remodel done 2 years ago.
All of the doors they put up or painted are now sticky and horrible looking. They get cleaned the best they can and within two weeks they look beat up and dirty again. It's hard to believe this is because of blocking, but my guess is, it has to be. I've tried every cleaner known to man and lots of rinsing to make sure it's not soap residue built up. It might feel a little better initially upon cleaning but within a week, it is sticky again.
All I know for sure is they were painted with a SW DTM paint by the paint contractor, who took some shortcuts that have shown up later on the walls. I do not know if he ever put a finish coat put on the doors beyond the DTM paint. I suspect he just put on 2 coats of the DTM and clearly did not let the first coat dry first. They are Bright White and they are rough to the touch and sticky and they are filthy and very hard to clean and hard to keep clean.
I'm trying to figure out the best way to fix them. Really fix them. I personally would love to pull all the doors, strip them down to bare wood sand them and stain them and put a oil-based poly on it. But that's not going to happen as it's too time-consuming and I don't have the room to do that on that kind of scale. We are talking about 20 doors.
So should I just clean off the dirt, sand it with 180 grit sandpaper, paint with some bullseye 123 primer and roll on a quality semi gloss latex with a foam roller pad? Or what? These are just plain flat commercial doors without panels.. Once they are done, I will be installing kick plates and push pads to help protect them, but that sticky paint, has got to go. I'm sure that's why they stay so filthy. Suggestions?
