1 - 7 of 7 Posts
I used Murphys Oil soap on my hardwood floor and it has left a sticky film on it. I heard to use some water/vinegar solution and it still seems to have a sticky film compared to where the Murphys was not used.
Does anyone know of a good cleaner or trick to remove this from my floors?
· Tileguy
Do NOT use Murphy's (or any soap) to clean anything. Soap leaves a film which will build up and attract dirt over time. It'll look fine for several years, but you should be using detergent that claims it doesn't leave a film. You still should rinse of course. Rinse..... who does that anymore?
You should really look into the Bona products for hardwood. Wood does NOT like water as you know.
Jaz
maybe I was wrong! I still seem to get a bit of stickyness after using the Bruce with microfiber mop.
What can I use to remove this? I can tell a big difference in the room that wasnt cleaned with Murphys versus what was.
Discussion Starter · #6 ·
I finally found a solution.
After a little internet research I found out a tiny amount of ammonia added to a squirt bottle of water will take the tackiness away! Now when I walk on it with my shoes you do not hear them sticking to the floor and making that squeaking noise.
1 - 7 of 7 Posts
