1 - 14 of 14 Posts
I have 2 Sterling 1.6 GPF toilets and I can't seem to find a good flapper for it that works the way it should. I do know that the flapper has to be longer vs the short flappers like a Korky for example. I have used Fluid Master because they seem to agree better with these toilets.
Lately I am having an issue where after the toilet is flushed water still trickles down into the toilet for 5-7min afterwards, I tried the food coloring test and there is a little bit that shows up even with the longer Fluid Master flapper.....any help is appreciated. Thanks
Sterling is a division of Kohler, and Kohler toilets - for whatever reason - seem to hate "universal" flappers like Korky or Fluidmaster. I agree with you that the Fluidmasters seem to work the best, though.
You could either get a replacement directly from Kohler/Sterling, or replace the whole flush valve with a Fluidmaster flush valve.
I tried a Kohler flapper with a float. It actually allows more water to trickle down into the toilet. When would it be actually time to replace the toilet?
Kohler has about a dozen different flappers, and probably more for their Sterling toilets. You have to have the model number of the toilet, and make sure you get the flapper that matches that model.
Thanks
Where can I locate the actual model #?
Discussion Starter · #8 ·
Found it. What if I just buy the tank?Bottom portion is fine. Although entire toilet is same amount as jut the tank would cost online or in some local stores. Wow
http://m.lowes.com/mt/www.lowes.com...=12&un_jtt_v_tabs=infoandguides#infoandguides
You don't need to replace the whole tank! But now that you have the model number, you can go on the Sterling web site, or even go to a plumbing wholesaler (not a Home Depot), and find the proper flapper for that toilet.
Discussion Starter · #10 ·
I bought a flapper that says it's for Sterling toilets at Ace Hardware, but the water trickles down even more into the tank. I don't get it.......
Yeah...a lot of those hardware store after-market parts are junk. You want to get genuine Kohler (Sterling) parts. Call 1-800-STERLING and talk to customer service. Give them the model number you found inside the tank.
Discussion Starter · #12 ·
No it's a genuine Kohler flapper.
You'll probably have to go back to "Plan B" and replace the flush valve. Fluidmaster makes a good flush valve, and (obviously) uses the ubiquitous Fluidmaster flappers if/when you need to change it.
There could be a nick on the seat of the flush valve that's preventing the flapper from making a complete seal.
Discussion Starter · #14 ·
How would I know for sure?
1 - 14 of 14 Posts
