Hey everyone!
I'd like to build a 12' x 14' steel pergola with 2"x6" beams. The total weight of the upper 12x14 rectangle is approximately 320 lbs. The two supports are about 45 lbs each and also 2x6's. The back of the rectangle would be anchored to the open garage structure behind the siding wall shown in the image. Some anchors would be bolted directly to existing studs and some to 2x6 blocking. The bottom of the angled 2x6 supports would be attached to the concrete garage foundation via Simpson brackets. The beams and all hardware are Fortress Building Products.
My question is whether this design will hold up. All you structural engineers out there please advise!
Thanks!
Thanks!
