I'm doing some renovations in my home, and I recently uncovered an area where a steel i-beam is resting on wood framing.
The kitchen was expanded at one time (I assume not by professionals, for various reasons) an exterior wall was removed, and the steel beam added.
I noticed that the only thing holding the beam in place is gravity, no brackets or attachment to the wood structure of any kind, just scraps of 2x4 ramsetted to the web of the beam to hold drywall. There is only two 2x4s under it, one looks like it was part of an old concrete form.
'm sure this wasn't any type of engineered project, probably just a piece of i-beam someone had laying around - the end looks like it was just cut with a torch.
Should there be some type of bracket or additional framing holding this to the wall? There's no worry of earthquake or tornado here in central PA... but I'm assuming there should be something more for support/attachment here....
Any suggestions or input is greatly appreciated.
The beam is 8"h x 4"w, about 1/4" thick, 12' span
