For some reason my house has a thick, metal drain pipe. I think it might be iron, not sure, but it is damn hard to cut through.
Two questions:
- Is there some trick to getting it apart at the fittings? Or at all? Cutting through four inch steel pipe with a cheap, battery powered recip saw is a huge pain.
- Once it's apart, what is the best way to connect it to PVC? It is already connected to PVC in another place with a rubber coupling - should I just use another one of those?
Two questions:
