1 - 2 of 2 Posts
I switched 2 oil steam boilers , both had 110 volt water feeders on them , the gas boiler is mostly 24 volt , like the low water cut off ,
Is there a way to hook up the 110 volt water feeder from the old oil boiler to make it operate with the new 24 volt Low Water Cut-off
some kind of transformer
and has anyone ever done this before
if there was 1 no big deal but 2 of them it is expensive , 220 dollars each
Semi-Pro Electro-Geek
You could use a contactor with a 24VAC coil.
1 - 2 of 2 Posts
