i have a HUNTER stat that used to be in use, about 3+ years ago. i took it off thinking it was a problem. till then, it would turn the furnace on for 20 mins and off about 40 mins @ 32deg outside temp.
i installed a basic new ( about 4 years old now)honeywell stat. it turned the furnce on for 8 mins and off about 20ish mins @ 32deg outside temp.
i think this is to much cycling. so, i put the HUNTER stat back on. house was cooled off a few deg when i turned it on. furnace ran for 8 mins, shut off, even though the stat temp was not reached and was calling for heat. then the furnace stated right up immediately .
this 8 minute thing. i thought it was the honeywell stat. but it "seems" not.
now, i'm confused. can a basic furnace have a setting for this 8 minute thing ?
its a 06 nordyne gas.
