I don't know if this should go in another section, sorry.
I was wondering if there were any changes I need to consider before changing a standard outlet to a recessed outlet. I don't wan to change voltage. It's just that the outlet is in a spot where if I plug stuff in, I obviously won't be able to push something up against the wall as close as I'd like.
If I change to recessed, will I need to change the wall behind it, or can I just attach the wires and slide it in position?
Thanks for any help.
