1 - 18 of 18 Posts
I need to replace a dishwasher. It's a standard size, however the cabinet space was not designed well. Part of the problem is that tile was installed, and between the 1/2" cement board and thick tile, it comes up quite aways. The cabinet space was designed without taking into account a thicker floor. The tile does not go under the dishwasher. That makes it extremely hard to get the dishwasher in and out, partly because the feet have to get over that tile lip when there is almost not play between the dishwasher top and underside of cabinet. (Of course I have screwed the leveling legs in all the way first.)
Are there any dishwashers that would make this installation a little easer? Basically standard dimensions, but possibly some adjustments or just ones that tend to have a bit more wiggle room?
I put backer board and tile in my kitchen and put it under the dishwasher. It is hard to put a dishwasher in a hole and leaks will be stuck under the dishwasher. I cut oak 3/4” by 5/8” thick and finished it to match the cabinets. Then I lifted up the countertop and glued the oak strips to the top of the cabinets, raising the countertop 5/8”. Then the dishwasher fit. It was when I replaced the tile backsplash so that was not an issue.
If you have room I recommend raising the floor to the finished floor height.
Find the pdf version of the installers guide online for considered models. They all have a range of heights they can be installed at. All the ones I'ne dealt with have an adjustment on the rear wheels as well as the front levelers.
Discussion Starter · #6 ·
I don't think you guys are understanding what I'm saying. The dishwasher will not fit under the cabinet if the floor there is raised to the level of the tile. As it is now, you have to raise the front legs, angle the dishwasher down into the space, and kind of power it through. It raises the laminate countertop slightly at one point in the process, because it's so tight against it. Then when you manage to get the dishwasher in you have to lower the leveling legs in front to level it. If the floor were level right to the back of the dishwasher space, the dishwasher would not fit under the countertop.
Also, the sides are very tight. One time, I busted off this plastic piece on the side which opened a hole to the inside. Not sure what that thing was, but I did get it back in place.
· retired framer
I understand that you need a machine that is at least 1 inch shorter than the normal, they are out there. You just have to find them.
· retired framer
Ditto. I just bought a dishwasher. I checked dimensions for sure. Even within one brand, models are slightly different sizes. Width does not change much -- height does change significantly.
Usually there is a "header" piece of trim that keeps the cabinets together until the countertop is installed. After the countertop is in place this piece of wood could be safely removed and provide 1' more headroom for the dishwasher.
As as side note when I replaced the cabinets in my kitchen I laid out 2x4 boards on the subflooring to raise the cabinets up 1-1/2 inches. These were covered with the kick panels and so cannot be seen. I was able to run the dishwasher power cord and the water supply line and the drain line through gaps in the 2x4 boards and so did not need to drill any holes in the cabinets. The extra 1-1/2 inch of height made the working height better at the same time.
· Framing Contractor
At my last house, I built the floor up with the dishwasher in place. I knew that if something failed with the dishwasher, I would have to sawzall the legs off, slide it out, and buy a newer shorter version. I took the gamble and worked well for the 5 years I was there prior to selling. You can take the same gamble.
If there is a1-inch "header for the cabinet to suppor the side units until the countertop is in place this could not be removed to provide more space for a dishwasher.
As a side note when I replaced the cabinets in my own kitchen I had 2x4 boards nailed down where the new cabinets were going to be and this made the cabinet height 1-1/2 inch greater. The kick panels cover the boards so they are not visible.
I ran the water supply, power line, and the drain line for the dishwasher through gaps in the 2x4 boards and so did not have to drill any holes in the cabinets. The extra working height for the new cabinets and countertop was also important. The added cost was only for 100 lf of 2x4 board.
Discussion Starter · #17 · (Edited)
So you were able to get it in. It was just a pain. If you are replacing the dishwasher, and want to fill in the floor flush to the tile, look for a ADA compatible dishwasher. It will be 2" lower than a normal one, but you may be able to adjust it up to fit.
That sounds like the perfect solution - solves both the height issue and the slide in/out issue. Now if I can just find one around somewhere at a reasonable price.
https://blog.designerappliances.com/content/images/2018/09/ADA-2.jpg
Discussion Starter · #18 ·
(1)
| Model# DW-UF-H-24
New ZLINE Kitchen and Bath 24 in. Top Control Dishwasher in Unfinished Wood with Stainless Steel Tub and Traditional Style Handle
$95995
Sound Rating Range (Decibels) Quietest
Height - Max (in) 32.5
Dishwasher Size 24 In.
Tub Material Stainless Steel Tub
Control Location Top Control
https://www.homedepot.com/b/Appliances-Dishwashers/325/N-5yc1vZc3poZ1z0x68x
Way more than I can spend, but now that I know the height I'm looking for that will help.
1 - 18 of 18 Posts
