I'm trying to finish my basement and I got stuck with the concrete wall next to the stairs (left side of the stairs).
I'm not so sure what kind of framing I need to do. There's only probably half an inch gap between the concrete wall and the stairs. I could may be just put a sheetrock maybe.
The big problem is the wall after the stairs. How do I frame it? If I do the normal 2 x 4, then, the wall would be blocking the stairs a little bit. Or do I even bother framing it and just put a sheetrock, glue it, nail it, and call it a day? Would that even pass the inspection?
My basement is below grade and I'm not sure if I need the insulation, 2 x 4 wall, etc. on that side to pass inspection?
Any help is greatly appreciated.
