In my main room, cathedral ceiling, I tied the rafters together right at the top plate - 2 joists bolted together on opposite sides of a rafter @ 4' intervals. These have been up for a couple years now. The original intent was to box them in at some point. I just recently added a "filler" 2x6 in between each existing pair, to stiffen / square things up and ended up with a sort of "laminated" beam - I don't mind the look so plan B now is possibly to just stain these boards as they are. But the one thing that worries me a bit is that the original 2x6's have darkened quite a bit, whereas the new piece that I sandwiched in the middle is very light. On a test piece, even with the dark stain I have, I get dramatically different shades. I'll end up with a "stripe" along the bottom. Is there a way to "prep" the wood - sort of like a coat of primer - prior to staining? I suppose a solid stain or just painting would cover well, but the wood grain, knots, etc. showing thru is kinda what I would like to keep if I can.
Thanks for any help...
