Stacked stone around fireplace
818 Views 1 Reply 2 Participants Last post by  Windows on Wash
We'd like to install stacked stone around this fireplace opening. It had brick previously. Is using cement board the best method? I'm a bit concerned about how to handle the joint between the opening and the board/stone.
1 - 2 of 2 Posts
How tall are you going to be running it?
Depending on the depth of the engineered stone, you can run a small return piece to trim out that section. Some manufacturers have both outside corner sections as well as trim pieces. Across a small'ish section, an outside corner section that is staggered will probably work best.
1 - 2 of 2 Posts
