After years of flawless operation, I started noticing a very light but continuous flow from the lowest sprinkler in the entire system (algae / moss on curb). For troubleshooting purposes, I capped the lowest sprinkler head, and then a continuous flow started coming from the next lowest sprinkler head.
I did some basic Google searching, and determine that the issue is likely a leaky control valve. I watch some videos, and thought for sure that I had a deteriorated diaphragm etc.
However, when I inspected the sprinkler valves for the area in question, the assembly looks to be nothing more than a solenoid sitting on top of a flow control “collar”. No housing with screws that would allow access to a spring and diaphragm.
Can anyone help me understand how this works? Do I simply replace the solenoid? I'm happy to do so, but would love to understand how better how this works, as I'm expecting the problem to return in the future with other sprinkler zones in our rather large yard.
Thank you!!!
· A "Handy Husband"
Call Rainbird tech support with the model number and ask about the repair parts and procedure.
Sent from my RCT6A03W13E using Tapatalk
· Master General ReEngineer
Ayuh,.... As with any faucet, there's a seat, 'n seal in there,.....
The solenoid merely actuates it,....
Might be an ASVF valve. Pull the model type of the valve (should be molded into the valve body) and head to YouTube. Somebody will be showing how to pull it apart and repair. Or, a lot of times you can replace the insides.
I once saw the one YouTube video where the guy was saying that if the valve won't fully close, it could be a rock or debris under the diaphragm. I figure "right, how on earth can a rock get under there after a dozen years". And then one time I found a rock inside my valve.
