I am installing a sprinkler system myself this spring. I have relativly low pressure (40-60psi) and only 8-9gpm.
My yard is a nasty shape. It bends curves, and I had trouble designing the head to head coverage. I planned it out so the sprinklers at least hit each other, and I have rotors planned that are only 15ft-20ft away from each other.Hopefully I can use smaller nozzles and decrease the distance......Wind is also annoying here in the summer. A development down the street from us has Rainbird sprinklers, and they're lawn is sickly green!
, I checked and it looked like Rainbird 5000 plus and have 2.0gpm nozzles. I can't find them online though for a good price though.
Questions Below:
- Hunter PGP-ADJ
- Rainbird 5004 (Rain Curtain?)
- Toro Prostream XL (HomeDepot sells them)
Questions Below:
- So, I narrowed down to a few different sprinklers. Which are the best for distance/low pressure and reliability to "pop down"? I've seen Hunter sprinklers that love to stick up after watering.....Also, best coverage underneath the stream of water?
- Hunter PGP-ADJ
- Whats the different from the 5000 plus and 5004 series?
- Is it ok that rotors are only about 15ft-20ft apart in some areas?
- Are more sprinklers better than not enough? Meaning, alot of the heads drown each other...
