Spray foam insulation between joists - will the foam get past the "X" bridging?
Hi all. The next step in my basement finishing project is to insulate between the ceiling joists. There is a wooden ceiling covering the joists that was put in some decades ago. Conveniently, I have some access to the area between the joists where I took out some old closets. I can easily step up on a ladder and see right down each of the joists.
Seems like a straight-forward insulation job with one hitch - in the middle of each space between the joists is an "X" shaped wooden support. Bridging, I think it's called?
Since it's X-shaped, there are cavities on any side of the bridging where something could pass through, but having never worked with spray foam insulation, I wanted to ask the group - will the spray foam just work its way past the bridging on its own? If not, can I work it past to the other side somehow? Would that be a huge pain in the ass?
Because of lead issues in the house, I really don't want to open up the other side of the ceiling.
Hopefully my question is clear. Below is a photo of the ceiling showing the exposed area where I plan to shoot the insulation from, if I can find a rental. Thanks all.
