I am a bit confused by all the different foam sprays in a can. GREAT STUFF, TITE etc...and they have regular, big gap, fire block, pest block, windows and doors etc...
Reading the instructions on each type of can, is to shake vigorously then fill < 50%.
Is the fire block foam truly fire resistant? Because the other stuff is labeled as flammable.
The windows and doors foam is formulated so it won't deform the frames when overfilled. So if you underfill it and check it after 2 hours (that's how long it sets therefore how long you have to wait before knowing if it needs more?). By then the can nozzle and tube are already set and blocked up right? So you need to buy two cans, use some of it out of the first can, and if you need to top off use a new can?
Since all the various types have identical instructions (fill < 50%) then they all expand at the same rate? The difference is how "hard" they expand? Windows and doors foam will expand gently the other stuff will expand to turn a Coke can into a base ball?
