1 - 6 of 6 Posts
Hi all:
Posted previously about agitator/auger problem. I thought it was the cam dogs. Turns out the unit is inseparable. Installed the new unit only to discover that the spindle is spinning INSIDE the new unit. There is a corregated metal cap that fits over the spindle and meshes inside the agitator/auger unit. Problem is that the spindle is spinning inside this cap, nothing is agitating.
Has anyone come up against this before? The spindle doesn't seem stripped--it's smooth to begin with. Is there a trick to this?
Thanks
#1 HAWKEYE FAN
no model number no help
Here's that number
Guess that would be helpful: 94802 / 94862
The unit is a "Laundry Center". I'm guessing the number on the left is the washing machine, the one on the right, the dryer.
Thanks,
J
#1 HAWKEYE FAN
sorry, but I don't have a clue about what you are talking about. Your washer is a Frigidaire built unit, the agitator is a one piece unit. The agitator slides over the splines on the transmission shaft and then a screw holds it in place. If the agitator is in place and screwed down and it still does not agitate then you probably have a bad transmission. BTW, that unit is one big piece of sh**
Discussion Starter · #6 ·
Hardwareman:
Thanks. you're right; it is a piece of crap.
The agitator does slip down over the splines on the hub, but the hub is a separate piece from the transmission. It looks like a large thimble. When I slip it onto the tranny spindle (that's not the technical name, of course), I can turn it, easily. It shouldn't turn at all. Could I have possibly STRIPPED the inside of the hub?
1 - 6 of 6 Posts
