I installed a 2.6A gable fan against the gable vent in my garage (the smallest I could acquire at Home depot).
It works great, except that it blows so hard that a lot of the hot air can't make it out of the gable vent itself. So I went and purchased a fan speed controller from a local electronic supply company, to slow it down some:
KBWC-15K -----------------------
The KBWC-15K is a Distributor packaged Solid State AC Motor Speed Fan Control. It is designed for mounting in a 2" X 4" electrical wall box. It operates from 115 VAC, 50/60 Hz and has a maximum rating of 5.0 Amps @ 40°C. The KBWC-15K provides infinitely variable speed motor control for Shaded Pole, Permanent Split Capacitor and Universal (AC/DC) motors. The variable speed motor control contains an on/off line switch, a high gain RFI noise suppression filter, a minimum speed trimpot and a flame retardant ABS enclosure. Applications include range hoods, vibrators, humidifiers, fireplace blowers, fans, laminar flow hoods, heat tunnels and stirrers.
There's a hum coming out of the motor now, and since I'd heard that light dimmers can burn out a fan motor, I disabled the electricity to the fan, in case I was accidentally given the wrong controller. Also, in looking through the fan manufacturer's documentation, it says not to use a solid state speed controller, which is exactly what this is, but it's description looks like it's meant for this particular application.
Could someone shed some light on this situation? Should I just let it run at full blast and remove this controller, rather than risk the motor?
Thanks,
--=Chuck
Thanks,
--=Chuck
