There is down the stairs a lamp with 2 bulbs. One is controlled by apartment A (by both a switch at the bottom of the stairs and 1 within the apt.) and the other by apartment B (which also has its own control with switches up and down). Up the stairs there is another lamp with 2 bulbs also operated separately from apartment A and B. Outside are 2 other lamps again the same control from A/B. In researching I would guess that this type of electrical wiring is called, SPDT switch-the 3 way light switching circuit. The problem is this. Apartment B and only apartment B has both switches working fine for the up lamp/bulb but doesn't work for the bottom light/bulb and outside one. In testing the bottom switch the problem was found, no electricity was flowing in it. Up to the circuit breaker box I went. All breakers were on. 1 by 1 I switched them on and off, 1X, 2X 3X. And still no power going to the bottom lights. I then moved on to testing the individual breakers. All worked fine except one. it actually worked in reverse, and by this I mean, when testing the other breakers i placed on tester wire on the wire on the breaker and the other onto ground. This 1 different breaker did not work that way unless I turned it off--then the tester did light up.
Could this be my problem? If so do I replace the breaker or should I change the wiring in the breaker? If this is not the problem than what could be it?
Thank you
Thank you
