I have a free breaker in my panel and can fit a tandem 20 amp breaker so that I can run two bigger circuits in my garage. The plan was to have about 4 double gang boxes with two outlets, one from each circuit so that I can space out the need. Anyhow, I shutoff my main house panel from the actual main panel that is outside so that I can connect the circuits. I ran two 12 gauge wires through one knockout into the box, the connected each ground to the ground bar, each neutral to the neutral bar, and finally, each black wire to the tandem breaker which was off. All good.
I ran the wires into a metal surface box where I'm going to run PVC conduit from there to the new gang boxes. As I was moving the wires to install the PVC connector, I got a spark. I quickly grabbed my tester and using the black and white wires, no circuit. As I moved the wires again, big spark and burnt the ground.
Why? The ground is what got me. Is this because its in a metal box? Should I connect the ground to somewhere on the box?
