I am seeing a small spark when i loosen the white(common) wire at the panel box, is this a problem? thanks for the time.
Only if you leave it loose:laughing:. But, you shouldn't be loosening wires that have a load on them to begin with. Why are you doing that?I am seeing a small spark when i loosen the white(common) wire at the panel box, is this a problem? thanks for the time.
Yes, yes it is...I just ran another curcuit and hooking to a new 20amp breaker, I was just putting 2 white(common) wires in 1 space. Is that wrong?
Yes, the spark is due to you intermittently making and breaking the circuit while something on that circuit is drawing current. It's the same as when you plug something in that is turned on and you see a small spark inside the receptacle.So the small spark is normal when there is a load present? Thanks
