Got a picture of the problem?
Here is a link to the thread I believe you're talking about:It sounds like you're anticipating a texture flash, where the patch area is smooth in contrast to the surrounding texture created by the roller previously. If you're not using a sheen finish, or you don't have strong sidelighting, you shouldn't have much problem, as flats generally don't reveal a texture contrast that obvious. Other than spot priming with a roller to add a bit of texture, don't use a brush or you'll make it worse, there's not much you can do. There was a bit of discussion about this topic in another thread, type texture flash into the search engine. It was fairly recent.
Prime with a roller like J suggested and after you are done painting the entire wall it should blend in fine. If you are really using spackle and not drywall mud I recommend priming your repairs twice, spackle tends to flash more.You were right, there is a texture. It's from the paint being rolled on. It doesn't really stick out, but it's noticeable when there are smooth spots here and there.
Thanks.
