First I want to thank everyone for advising me on my "bad spackle" post. I will be tackling that DIY tomorrow.
When we bought the house about 7 years ago a friend of ours( has since moved) who helped with some carpentry did a popcorn ceiling spackle
. He said it could be done and we were like whatever, we trust you....ok. It came out fine. A few questions about the ceiling(see pics).
1. We installed a skylight some time ago and some re-spackle had to be done. Well as you can see it did not match the original. If we repaint the entire ceiling I would imagine it would match then, correct?
2. The seems to be settlement issues as you can tell by the pics. By the crown molding were the caulking is it is separating in some places. Also there is a line straight down part of the ceiling. There is a low spot by the skylight. I would imagine these are settlement issues. Any advice on what I should do/check?
Went back to edit due to the fat I forgot to dd the pic the shows the small low spot by the skylight. The pic of the skylight here shows the mismatch due to the re-spackle.... You can't see the low spot to the back left of the skylight.
Would these questions be better on the carpentry forum? Thanks
