We have a bedroom that does not have air return and does not get conditioned properly. The door has a 1/4" bottom crack to the carpet. We had the door replaced a few years back, after one of or kitties was inadvertently left closed in the room and did a job on the inside veneer layer trying to get out. I suspect the door used to have a wider opening on the bottom.
The question is how wide the crack should be. The bedroom has two feeding vents that look like 3x12, but the feeder duct from the basement, if I got it right, is a 6" duct that switches to 3x7 in walls.
