Quick question-
I currently have a 12-2 gauge three wire (black, white and copper) running from the basement to the air handler up in the attic.
The Air handler calls for a 208-230/60/1 power supply.
The high voltage block on the air handler has an L1, L2, N and a grounding lug on it.
Question:
How do I connect the wire at the CB panel and the air handler?
Here is what I was thinking....
At the panel: Get a 20 Amp double pole CB and connect the BLACK and WHITE lines to the CB and the copper ground to the nuetral bus bar at the CB panel.
At the air handler: connect the black wire feed to the L1 terminal, the white wire to the L2 terminal, and the copper to grounding Lug.
Does this sound right?
Question:
