1 - 18 of 18 Posts
Has anyone found soundproof drywall for their media room? I am unable to find it and we live in southern Ontario. I wish to add this to the exsiting drywall to lessen the noise level in the master bedroom. Thank you.
The thicker the drywall, the less sound is transmitted. So if you installed 5/8" drywall over the 1/2" you would have a total of 1 1/8" thickness.
You could fill the stud cavities with blown in cellulose insulation.
When I built my house, I built the bathroom walls using 2X6 top and bottom plates and off-set 2X4 studs.
Then I wove insulation bats in and out before installing 1/2" drywall to close the walls in.
As sound is 'telegraphed' through the studs, using off-set studs provides a 'break' between the two drywall surfaces!
In your case, if space permits, you could build another insulated wall, making sure there is no contact between the two walls and then finish the new wall off with 5/8" drywall.
· Registered User
I've used Green Glue with excellent results. No special drywall necessary, just 28 ounce tubes of green glue.
http://www.greengluecompany.com/
Since you already have existing drywall, you just squeeze 2-3 tubes randomly on the back of the new piece of drywall, lift it in place and srew it up.
I used 5/8" Type X drywall. It has a denser core which even by itself, provides quite a lot more sound deadening than just one sheet of 1/2".
I use the green glue on all the walls and ceilings in all the home theaters I build. you have to plan ahead with hvac pipes and other openings that will allow sound to be transmitted through them.We also use sound isolation clips to hold the drywall off the studs and joists which keeps the sound from transmitting through the studs to the other side.The really low bass vibrations are the most difficult to stop but we have never had to return to a customer location where we used green glue, staggered studs, insulation and sound isolation clips.we just build houses and do remodels and are not expert soundproofers but our customers was reasonable cost with good results and we found the above to work best without breaking the bank.
· Lic. Builder/GC/Remodeler
Quiet Rock; http://www.quietsolution.com/html/quietrock.html
We've installed it in many locations (some - per engineer design requirements), including Hospitals and Hospital executive offices (Patient confidentiality concerns), media rooms, private theaters, apts, condos, etc, etc, etc.
It works, especially when installed with sound attenuation batts, and additional sound deadening constrution practices: Staggered framing, acoustic caulking, dampening pads, resilient channel, etc....
1 - 18 of 18 Posts
