I now bring you the next episode of "Eric Builds A Deck"
Ok, so thanks to the wisdom of this community and a little additional research on the LedgerLok engineering specs, it seems securing my ledger to the 1" OSB rim is AOK, or I can cut out the OSB rim and put a 2x rim joist on the sill plate secured with blocking between the joists.
But now I face one more conundrum.
Given (1) that the bottom row of fasteners must be 6.5" from the top of the ledger according to figure R507.2, but not less than 2" from the bottom of the rim, and (2) that a step must be be at least 4" tall to not constitute a trip hazard (if I understand correctly), and (3) my deck is L shaped with the door in the inside corner of the L, I am left with the following options.
A. No step and slope the deck for drainage. Pros: Draininage. Cons: possible snow build up and moisture invasion of the sill/house.
B. A 4" step, but no slope for drainage. Pros: Step helping to protect the sill/house. Cons: No run off of water.
I attach a drawing detailing the two scenarios:
So which is the better of two evils? (Note that I am using composite decking with spaces so maybe the slope is not that important as long as it is definitely not sloped TOWARD the house?)
-Eric
-Eric
