Hi guys, just have a few quick plumbing questions. If you have some free time and don't mind helping me out, please feel free in answering some of them.
1) I was recently asked by my local water department to dig out the mud around our water meter and the pipes around it in our front lawn. The water department had said that if the pipes were covered in mud, that they could cause the pipes to freeze and that is why they wanted us to dig out the mud (since they own the meter, but do not own the pipes they said I had dig out the mud around the pipes, not a big deal to me). My question is, wouldn't the mud actually help insulate the pipes and help prevent it from freezing? And why after 30 years are they asking to now dig out the mud around the pipes?
2) They say when plumbing, to not have two unlike metals touching in plumbing applications due to the potential of corrosion by electrolysis. My question is, with brass valves and sillcocks that are attached to copper plumbing, does one need a dielectric union to prevent corrosion since I am attaching copper to brass? Or is brass considered a neutral metal that will not result in electrolysis between it and copper?
3) When are dielectric unions necessary?
4) Why don't water meter pipes generally freeze? Where I live, we have had winters where the temperature was 0 degrees F, and the water meter pipes still didn't freeze. It is outside in the ground only covered by a metal water meter cover, I would think that is not enough to keep it above freezing temperatures, right?
5) If the answer to question 4 is that it does not freeze due to water flowing through the water meter pipes since water is intermittently being used by the homeowner, then what happens if the homeowner is on vacation for a few weeks in winter, won't the water meter pipes freeze then since the water won't be flowing?
Thanks a bunch guys, just had these on my mind and wanted to get some clarification. Take care and happy Thanksgiving
