I need to run service for receptacle to my dock on the lake. the dck is taken odd the water for the winter, so I would like to be able to disconnect without messing with a junction box. I have a receptacle 6-8 feet from the dock with GFCI upstream. I was thinking about running a liquid tight conduit properly strapped with heavy nylon ties on the inside of one of the dock aluminum trusses and flex it up to one of the posts/legs and finish it wirh a water tight device box. On the land end I would like to run the flex loose on the ground under a 4' connecting ramp and plug it to a receptacle.
Does this seem like an acceptable solution?
Are there terminating plugs for flex conduit? If not can I terminate it on a "loose" box and run a pig tail out of it?
