1 - 7 of 7 Posts
I just installed a 25 watt solar panel on my boat to keep the batteries fresh. I also installed a controller to make sure the batteries don't overcharge. The panel output was 21 volts before the controller according to my multimeter, after the controller it is also 21 volts. I would expect the output from the controller to be more like 14.5 volts. When connected to the batteries it drops to 11.8 ( the batteries are discharged) and the controller reads "charging". Is this normal?
· Super Moderator
DC supplies will often FLOAT high. You need to put a load on them get a true voltage. I would monitor the voltage as the batteries charge and make sure it does not rise above 14.5 as the batteries take on charge.
The 21 volts is apparently the open circuit voltage for your panel. It is all voltage, no current. With a load on it (the battery) it dropped to the lower voltage.
The charge controller should be using a high enough voltage to deliver the charge to the battery. But at the same time, it uses a lower voltage to provide maximum watts to the battery. If it just cranked away at 14.8 volts, it would deliver less watts than it will at lower voltages.
Your trickle charger is not going to charge a marine deep cell battery that is at a significant discharged state, which I suspect from the 11.8 volt reading. It's real intent is to combat the self discharge of the battery.
I would but the battery on a charger and bring it to full charge. Then connect the solar charger to maintain that state of charge. I believe you will see a higher charging voltage with the battery at a higher state of charge.
Thanks that's what i suspected but I just wanted confirmation. I did't want to overcharge the batteries. The boat is in a boat yard so I can't leave it plugged in to a charger unattended. For some reason they get all funny about leaving extension cords plugged int to tightly packed unattended fiberglass boats. The panel is rated for 25 watts, so if it shows 21 volts that are dropped down to 12, it's putting out 3-4 amps? I'll check on it tomorrow and see if the voltage improved. I hooked it up to the house bank, after the isolator. I am hoping that once they exceed 13 or so they will also charge the start battery.
25 watts at 12 volts is just over 2 amps.
That is also dependent on having full sun. With the sun lower in the sky, it will produce less. Air pollution or fog, clouds etc, can affect the output.
At this time of year in the northern areas, you might only get the equivelent of 2 hours of full sun a day. In other words, about 4 amp hours.
Southern areas might get 4 hours of full sun, or about 8 amp hours. These figures will go up in the spring/summer.
Those amp hours are based on the panels potential output. What the controller puts into the battery may be lower.
1 - 7 of 7 Posts
