1 - 8 of 8 Posts
Good chance (but not 100%) the hole spacing will be the same. If you get the hinges from a place that gives you and actual BLUM part number, you can do an internet search and quickly find the all the mounting dimensions.
For the mounting clip, again, I don't see a BLUM part number on the hinge, so I can't comment on the appropriate clip for it. But the time I needed an angle restriction clip, I used something that looked like this one:
Rectangle Font Parallel Technology Electronic device
Thanks for your reply. I don’t have any of the docs on my current hinges so if I get mounting dimensions for a new I cannot compare it to the old. 71T3590
I believe its the Blum 71T3590. I don’t have any of the docs on my current hinges so if I get mounting dimensions for a new I cannot compare it to the old. Or are you suggesting to get the new dimensions to see if the current holes line up?
You don't need documents for the old hinges --- you have the actual hinges right in front of you, don't you ? Measure them, and the location of the 35mm pocket from the edge of the door.
BLUM dimensions HERE page 78/79
Part number for 86 degree stop clip is on page 78
1 - 8 of 8 Posts
