1 - 10 of 10 Posts
Hello I have a question about soffit vents our house is 1200sq we have 5 roof vents and 5 soffit vents on one side of the house and the other side doesn't have any soffit vents that is the side of the roof vents. All of our water lines are in our attic could that be why we don't have any soffit vents in the attic?
Trying to figure this out if I need to add more.
I hope someone can help me out
Thanks..
We will need to know your climate, hope it is very warm with water lines in the attic.
Generally, soffit and roof venting is intended to keep the attic close to the same temperature as outside. Air flow is generated by either a difference in temperature or by the wind.
Why they would put soffit vents on one side only I'm not sure. Often roof vents are placed on the back side of the house for cosmetic reasons. But total vent ares is still important.
Bud
Reactions: craig11152
We live in Washington State the roof vents our on back of our house its a gable type roof. On the front of the house that is where the soffit vents ours and they are only 4" by 8" I am guessing there is 5 of them.. Not sure why they didnt put them on the back of the house the only thing I can think of is the water lines our close to the back of the house..
Some areas of WA do get very cold so need to know if you live in one of them.
using the 50% reduction in vent area for bug screens an louvers, 5 of the 4x8" vents would give you about 1/2 ft² and with a 1,200 ft² attic floor you should have closer to 4 ft². Half of that if the ceiling below is well air sealed (few are) and has a vapor barrier.
The same amount of vent area is needed for the upper area.
But those water pipes are a concern and really shouldn't be up there. Is the house built on a slab or does it have a basement or crawlspace?
Bud
Maybe its a regional thing but I've never seen a 4v8 soffit vent.
all the major manufacturers I am aware of make 4x16, 8x16 and a couple make 6x16 but those 6's are not often stocked.
Regardless I think the addition of soffit vents can't hurt and as far as water lines go I can't hardly imagine depending on a lack of attic ventilation to keep them from freezing.
· Property Mgt/Maint
going by recommended NFVA calculations of 1 sq ft per 150 sq ft of attic footage it would require 8 sq ft total of NFVA for your 1200 sq ft house. Fifty % coming from exhaust vents or ridge and fifty % intake or soffit. Of the 50% coming from the soffit that should be split between each side and continous from end to end.
So ideally you would be looking at 2 sq ft or 288 sq inches of NFVA of vented soffit per side.
But even with all that said, are you seeing any signs of needing more ventilation.
Shingles curling from cooking in the summer?
Condensation in the attic? Mold?
Discussion Starter · #9 ·
sorry We are on slab on grade and the vents are 4x16 We live in Puyallup WA
#Yodaman we have alot of humidity in the house and we had to fix both bathroom fans since they where not insulated and the range hood vent was not insulated.
we have mold up in the attic.. We have been here for 8 years and just trying to fix this stuff.. this summer I will remove all the mold..
Yup, you are on the tropical side of WA. As I sit here at 22% RH it is difficult for me to advise people about ventilating their house or attic when they have a rain forest outside. Not quite, but your outside humidity is a problem.
When you say "not installed" in regards to those fans, do you mean not at all or they were being vented into the attic
You should probably become comfortable with relative humidity, temperature, and dew point. And you should be monitoring those numbers inside your home and your attic.
An ideal solution would be 4" of foam on the roof with new sheathing and shingles, converting your attic from a vented space to a sealed conditioned space that would share the heat and air conditioning from inside. That approach eliminates the decision of when outside air is good or bad to be entering that attic. I'm certain this is not on your option list but wanted to state it as the optimal solution.
As a vented attic, you will have to deal with the outside humidity.
For your house, if you are experiencing high moisture levels there are some small steps you can take.
1. Switch to low flow shower heads that have a flow control at the head. That flow control allows the user to further reduce the shower volume at times during the shower. And limit the duration of the showers.
2. Be sure the dryer is venting to the outside.
3. No cloths drying inside.
4. No firewood stored inside.
5. Once you get the bath fan going, install a delayed off switch to allow the fan to run for a pre-selected time after you switch it off, 20 minutes is common.
6. Do you use natural gas for cooking and heating? If so, burning NG produces a lot of moisture so run the kitchen fan any time the stove is in use.
7. Be sure your gas water heater is not backdrafting as that will be dumping moisture into the house.
8. Do not use any ventless gas heaters, lots of reasons, including moisture.
Pick up a couple of RH meters to start getting used to the numbers around the house.
Bud
1 - 10 of 10 Posts
