Here's my original thread : http://www.diychatroom.com/f19/what-going-here-133078/
What i've done since the last time I posed in that thread : I've removed cabinets from the other wall (with my wife's blessing) that were impairing my ability to check level across the entire room.
I used a string line (very tight) and a line level to check the top plates from exterior wall to the wall in question, and it looks that the wall in question is lower than the exterior wall by about the amount that the top plates are distanced from one another in the original thread.
I did the same thing with the bottom plates with the same result.
Between the two walls, the floor system has 2 beams. The sag is not noticeable by eye until between the load bearing center wall, and the adjacent beam.
My plan is to set my string / line level on the beams below the house, and jack up the beam ~1/2" or until the line level reads "gravy"
Looking for any insight or things that I need to be careful of when i'm doing this. Thanks in advance.
