1 - 6 of 6 Posts
ok,
yesterday we had a brown out for a couple of seconds and my digital photoframe reset
now when I put it on the screen went very faint, then it's flickering.
so I'm trying to prove if the frame has blown something or the psu adaptor box
I noticed the box says 12v switched mode power supply and the 3.5mm jack has like a little red ring, where the black insulator would be on another one
I have a tosh laptop, with what looks like the same size jack and it fits the hole BUT the jack wont go over the inside pin, I'm assuming this is for compatability.
I don't wanna go and buy an SMPS never having heard of them before today
but can I use my laptop PSU to see if the digital frame works, I'm assuming it is otherways compatible
or do I have to use an SMPS with SMPS and a linear with a linear
txs !
I tried my laptop adaptor in the end, it made the screen even dimmer, the ampperage was a lot less. I think SMPS's have higher current for it's size.
My Rogers Cable box has a 3.5 15v 3a adaptor was meaning to give it a try.
I took apart the frame and nothing obvious stuck out, i.e. no cap's blown.
I'll see if I can use it, I was meaning to put a cheap laptop and an extended monitor in its place. I've gone through 2 photoframes now. They really don't seem to be very good !
BTW the photoframe was on a mains bar which had a spike/mains filter in it... didn't obviously work LOL
txs again!
1 - 6 of 6 Posts
