What sort of OSB was used with the suggestion you did not have to cover it with some sort of membrane---especially if outside. I do not mind the stuff as much as some but if any water or serious moisture gets to it, it will swell and crumble? Usually builders wrap the stuff fairly quickly in tyvek or something.
I guess you could use some sort of sealing resin product and I have seen artsy OSB walls in interiors done this way. Look awful to me. But you do plan to prime and paint.
You cannot just float 1cm stucco (plaster is really used only for interior surfaces these days) without it being attached to something.
You could try thin metal plating, or argh ick, vinyl. I guess if going for a smooth look, for whatever reason. You do realize any attempt at a perfectly smooth exterior surface is going to dent and ding quickly right?
