I finally located the hardwired smoke detector hidden above the drop ceiling on the finished side of my basement. Manufactured in 1990! I plan to replace it with a photo-electric smoke/CO detector.
The detector is close to the stairwell. The furnace, water heater, washer, and dryer are on the other side of a wall. However, the air space above the drop ceiling leads directly to the furnace area.
My question is, should I mount the detector on the drop ceiling panel or maybe just install a grill to allow airflow to the detector? Like this: http://www.firenuggets.com/avillo/0811_7.jpg
(I'm also wondering why the drop ceiling panels are so tight! If I can get them out of the frames, I usually snag on a wire. The panel I removed to access the smoke detector, I ended up breaking it in half!)
