1 - 6 of 6 Posts
The bottom sill on the old windows I'm replacing have a slight slant downward. When I put new vinyl windows in, how to I deal with the angle created under the new window by the sill. I would assume some sort of shim is created for underneath the new window???
Going to have to guess you mean your installing replacement windows.
If so they come with a sealing strip to take care of that.
Just have to cut them to fit.
When I install them I shoot in a small amount of low expanding foam to fill the gap.
I think Hina means that getting rid of the wood frame the window is going to fit in is the best possible thing to do.
In my case, I had PVC box windows installed into existing wooden frames. BUT, I made up plastic (PVC) flashings that I caulked onto the bottoms of the PVC windows to act very much like a "roof" to keep the rain and snow melt water off the wood. Those PVC flashings stick out over the bottom wood frames a good 1/2 inch so it protects them from both Sun and rain. Also, the PVC flashings are about 1/2 inch above the wood frames so that if that wood ever does get wet, the flashings will allow that moisture to evaporate without allowing any rain or melt water to get that wood wet again.
I'm convinced that if you take reasonable measures to protect an existing wood frame from getting wet, then installing PVC box windows into existing wood frames is OK, but you have to make sure you protect the wood at the bottom of the frame from getting wet.
1 - 6 of 6 Posts
