1 - 6 of 6 Posts
I am installing a new granite countertop over the holiday and have a question about how to install these small pieces of hardie board. IT is 1/2" thick and about 1.25" inches tall.
I tried using hardie board screws and it broke in half. I also tried using some roofing nails I had with the same result
should I try drilling pilot holes through the backerboard so it goes through no problems???
here is what i am trying to do
Retired Moderator
Are you simply using that as a sub base for a slab?
If so the cracked backer should bot affect the slab---you did not mention the brand of backer board---Hardie is difficult to set and frequently had issues with protruding screw heads----I use Wonder board or Durrock.
Retired Moderator
Finish attaching the backer--set the slab in a bed of thinset and you will be fine---
Next project use Wonder board--
1 - 6 of 6 Posts
