the cold water to the bathtub and washing machine is running at a slow trickle. How do I unstop the water lines?
not much info did it ever work?? If so in the cold water hose their is a screen see if it is plug?? as far as the bath tub cold water don't know what kind of tube unit you have. can't help their. Is the cold water ok in the rest of the cold outlet's??
Doing it myself
Washing machine is most likely clogged screens. Shut off the valves, remove the hoses from the washer and clean the inlets.
The valve probably has whatever is clogging your washer lodged inside of the cartridge or stem. Depending on what brand it is, disassembly can be difficult.
The supply valves turned on? Has any work been done where the valves were closed?
Both lines simply started to trickle over night or what?
